B23f combustion chamber cc
Old Feb 15, 2013 | 08:40 PM
tdrendel's Avatar
Default B23f combustion chamber cc
Rebuilding a b230f with a b23f head. I have flat top pistons on the way how do I figure the compression radio? The hight of the new poison is the same as the old just no dish.
Old Feb 16, 2013 | 12:57 AM
displacement should be same (pi*diameter^2/4*stroke)
total volume is the sum of the displacement and static volume. you can probably estimate the static volume as a bunch of small thin cylinders using the same formula
the compression will be the ratio of total/static
Old Feb 16, 2013 | 12:43 PM
tdrendel's Avatar
They are over sized to 96.6mm there is a ridge at the cylinder top so I am going to bore the cylinders
alienek
Sep 23, 2012 04:17 AM
alexi3rdgen
Apr 27, 2012 05:39 PM
HotCoil
Mar 20, 2007 07:20 PM
HotCoil
Mar 17, 2007 08:55 PM
axelm
Mar 21, 2006 08:54 PM
