B23f head on a b230 anything I should be concerned
Old Jan 28, 2013 | 01:54 PM
tdrendel's Avatar
Default B23f head on a b230 anything I should be concerned
last week my engine blew and I have had no luck finding a b23 to replace it with but I have found a potential b230
I will be rebuilding the b230 with new bearings and poison rings then I am planning on putting all of the b23 components back on the new engine including the head
Are there any concerns I should have with this swap?
Old Jan 29, 2013 | 12:30 AM
brickrunner's Avatar
How many miles did the engine have when it blew?
Old Jan 29, 2013 | 12:31 AM
analogies's Avatar
If you take care of the inners, as you said, bearings, rings etc...
well as you know the turbo had lower compression...120?
and the normally aspirated engine compression was or is...190?
I got me a 740 turbo head and slapped it on to my 87 240 wagon...only modification: remove the distributor cap from the back of the 740 head and replace it with the 240 rubber grommet...that is it...bolt on.....
your inners will be different...like crankshaft counterweights and longer rods..."low friction" upgrades on the guts...oil return line will need to be addressed if you go from Turbo red block to NA red block...that is what I've read...
Old Jan 29, 2013 | 01:17 AM
early b230f's had weak main bearings, later ones fixed that.
analogy: your 740 turbo head and 87 240 wagon were both B230, the OP has a B23F head he wants to put on the B230F block (not sure why he doesn't just use the B230F head the engine came with, but...)
btw, compression is specified as a ratio, like 9.5:1, 7.0:1. The turbos are around 7:1, while the NA engines are 9 or 10:1...
Old Jan 29, 2013 | 03:00 AM
analogies's Avatar
Oooooh....I see, I will blame it on the scotch...
Old Jan 29, 2013 | 04:03 AM
heh. PUI... posting under the influence.
Old Jan 30, 2013 | 09:56 AM
tdrendel's Avatar
My b23 only had 100k but its an 83 and drove it hard the replacement short block is from a 92 but I will be replacing piston rings, and bearings
So as long as the head bolts up and there are no timing issues il be happy
Old Jan 30, 2013 | 11:01 AM
our 87 (b230f) has about 400K miles on the engine. never even had the valve cover off it. doesn't burn any oil, still has good compression and power
we've not even been religious about oil changes, sometimes I realize we've gone a year and the oil is this nasty nearly black stuff.
Old Jan 30, 2013 | 02:15 PM
tdrendel's Avatar
Thats the worst thing about my engine blowing is the oil looked brand new
I drive it to hard beat on it a little to much I suppose
But after this build is done she well be like brand new again apart from the numerous suspension issues hah
So as long as the head bolts up and there are no other issues to worry about
Baldmccartney
Jan 18, 2015 09:45 AM
jongrappin
May 17, 2013 07:22 PM
Duanob
Aug 3, 2012 11:20 AM
tdrendel
Dec 14, 2011 11:18 PM
holiday_wagon
Jul 7, 2011 06:53 PM
