Bad Acceleration
Old Dec 5, 2023 | 08:32 PM
teeth's Avatar
Default Bad Acceleration
Ive got a 91 240 and for nearly a month now its been struggling to drive. It has a very poor acceleration. I can only get it up to speed limit if I barley press on the pedal and let it build up speed slowly. The fastest ive gotten it is 60. If i attempt to press the pedal down anymore the car will completely lose all acceleration and start to "sputter" or "bog down" (for lack of a better word). I can put the pedal completely to the floor and the car will actually slow down.
So far I have replaced the Fuel pressure regulator, every fuse, the IAC, I cleaned the throttle body and the MAF sensor (which got rid of the code it was giving me), The air and fuel filter, the oil, the transmission fluid and the throttle position sensor.
Not sure really what to do next. This is my final effort on getting this fixed before i sell for scrap.
Thanks for your time.
Old Dec 5, 2023 | 09:03 PM
Is there a large air leak in the plastic hose from the AMM to the throttle body?
Old Dec 6, 2023 | 03:38 PM
teeth's Avatar
Last I checked there was not. I will check again when I get home from work.
Thank you.
Old Dec 6, 2023 | 08:31 PM
Johnsf's Avatar
Air leak or no acceleration enrichment.
teeth
Jul 29, 2023 11:26 AM
NicP2S60
Jan 13, 2023 09:48 AM
Ryeman
Oct 25, 2021 12:47 PM
jamesrshelby
Apr 9, 2019 02:06 PM
Bostontrey
May 19, 2017 10:47 AM
