battery discharging on a 92 240DL
Old Apr 30, 2008 | 09:29 AM
gabyman97596's Avatar
Default battery discharging on a 92 240DL
Ok the the battery is waking up dead everytime i charged it I want to autozone they say the battery is ok the altenator is chargin. they say sometime is causin the battery to died dont know what it cpuld be we took it to an electromechanic he say it was a relay inside the dash and that he needed to dismantle all of it he is not a volvo specialist so i didnt do the job i didnt trust him. so what u guys think my problems any info would be aprreciate it thanks in advance
Old Apr 30, 2008 | 09:45 AM
kcw12's Avatar
Default RE: battery discharging on a 92 240DL
You've got a short somewhere bud. Id get a test light and see where its coming from.
Old Apr 30, 2008 | 04:38 PM
blue goose's Avatar
An ammeter inserted between the positive battery terminal and the positive battery cable should read about 5-10 mA, depending on your clock and radio. Before disconnecting the battery cable turn the radio off. Some radio codes get messed up if the juice is cut off while it's still turned on.
If the ammeter reads significantly above that you can isolate the problem. Remove fuses one at a time from the fuse panel and watch the ammeter.
Sometimes the glove box light stays on. Sometimes the overhead courtesy light stays on.
Post back.
mal81394
Jan 6, 2015 10:15 PM
Jeffers
Nov 21, 2012 06:50 PM
mrcanon918
Sep 24, 2009 12:35 PM
cmercon
Feb 2, 2009 02:15 AM
Gene Brink
Dec 15, 2003 03:20 PM
