battery/ possible starter issues
Old Aug 6, 2008 | 09:03 AM
salazarbuchan's Avatar
Default battery/ possible starter issues
Hello. So I drive a Volvo 244 '79. My battery went out and I put in a new one, that worked fine for a few days then it went dead again. So then I figured it was the alternator, but when I tried to jump it the car still wouldn't start. I took out the battery and put it on a charger and filled it back up. So then I reinstalled it, turned the key once and all my power came up, then turned it to start the engine and I heard a click and lost all power. So then I unhooked the battery and reattached it, tried again and the same thing, power came on but once I tried to start it there was that click and then I lost power. So i know my alternator is bad, but I need to get the thing running at least long enough to get it to the mechanic who can switch out the alternator. Any ideas what I can do? Thanks,
-Sean
Old Aug 6, 2008 | 10:22 AM
blue goose's Avatar
Default RE: battery/ possible starter issues
I would have it towed. Same thing happened to me and I tried to make it to the shop. The car died in the left turn lane and I had to call AAA from my cell. Meanwhile I blocked traffic for 20 minutes.
Starting out with fully charged battery and bad alt might get you 1 mile or might get you 10 miles. Meanwhile you're killing the battery, which is not a deep cycle battery, just a starting battery.
Old Aug 6, 2008 | 10:42 AM
TheRev240's Avatar
Go downhill.
Old Aug 6, 2008 | 10:51 AM
TheRev240's Avatar
i made it 20 miles on a bad alt and a full charge. But I went straight to a volvo mechanic to change my alt. I may have been lucky so don't take it for granted. Make sure you have them check your started too. Never can be too careful.
Old Aug 7, 2008 | 04:54 PM
wojeepster's Avatar
Clean and tighten your battery terminals and make sure your battery is fully charged. When you get it started measure the voltage across your battery terminals. Should be 13.8-14.4v
Old Aug 20, 2008 | 06:05 PM
fredbyte's Avatar
Gee, it's not that hard to change an alternator.
angusjustice
Feb 27, 2012 08:45 PM
ChiVolvo
Oct 23, 2009 09:52 AM
mrcanon918
Sep 24, 2009 12:35 PM
Chadley
May 20, 2009 04:11 PM
meb7070
May 27, 2008 04:29 PM
