Bleed Steering Rack?
Old Mar 23, 2010 | 08:52 PM
amazon2's Avatar
Default Bleed Steering Rack?
Just put a rebuilt Cam Rack in a '78 240 and it spins all the way to the right as soon as the engine starts and I have to fight it hard to bring it back or turn left at all. I notice there are two plugs on the rack near where the external metal lines run along the rack. Is there some sort of bleeding procedure?
Old Mar 24, 2010 | 04:43 AM
Typhoon's Avatar
Bleeding a steering rack simply involves turning the rack lock to lock with wheels off the ground until the fluid is not aerated any more.
I hope that solves your problem, but it sounds like a problem with teh valve to me.
Regards, Andrew.
Old Mar 24, 2010 | 10:02 AM
amazon2's Avatar
Default teh valve
Regards, Andrew.
Thanks for the info. I'm guessing that I got a faulty rebuilt rack since I had no problem other than leaking with the old rack thus no reason to suspect contamination causing the teh valve to stick, which I think is what you're saying. What does teh stand for? TD
Old Mar 25, 2010 | 02:42 AM
Typhoon's Avatar
Teh stands for dyslexic typing! I always type the as teh.
Try bleeding the rack before you get too excited, it may just have an air lock.
Regards, Andrew.
Old Mar 25, 2010 | 07:03 PM
Sofar.'s Avatar
For me "teh" stands for tiny netbook keyboard.
timmins
Sep 28, 2022 02:00 PM
maduko
Nov 21, 2011 09:03 PM
redbriq
May 5, 2011 10:40 PM
intence
Mar 3, 2008 08:40 PM
katiejoyful
Dec 12, 2007 04:49 PM
