Body Trim Popping Off
Old Mar 14, 2006 | 07:57 PM
mikrin's Avatar
Default Body Trim Popping Off
My 1992 Wagon's trim mouldings at the bottom of the doors are popping off. They don't look like they have brackets, are they glued on? If they do have brackets, then the moulding is warping and pulling away at the ends. How do I stop that or fix it. Thanks.
Old Mar 14, 2006 | 10:06 PM
Default RE: Body Trim Popping Off
You will need to buy new clips and install them. They go in the holes you see in the body.
Old Mar 17, 2006 | 01:38 AM
mikrin's Avatar
I don't see any holes. The trim is flaring out at the ends. I'll try and post a picture tomorrow. Thanks
Old Mar 23, 2006 | 12:31 PM
mikrin's Avatar
It appears there was a pin, but it was molded on to the inside of the trim and it looks broken off. There is a hole in the door, but I don't know how I'd get a clip on my trim as there's no hole, just a broken bit of plastic.
mikrin's Avatar
Sorry, the picture didn't attach.
[IMG]local://upfiles/3726/2FCCE88F54DC438188169F92EF8D27E7.jpg[/IMG]
Old Mar 23, 2006 | 12:38 PM
tupapison's Avatar
the same was happening to me, and i glued it together with krazy glue, and that was 6 months ago, and its still perfect
Old Mar 23, 2006 | 10:57 PM
Look really closely at the molding almost all clips are replacable.
They should snap onto the grove in the molding.
hovonogila
May 16, 2019 02:28 AM
djbrndo850
Dec 31, 2014 07:14 AM
Hi_miles850
Nov 14, 2013 08:29 AM
poor_red_neck
May 6, 2009 11:49 AM
maddycom
Aug 12, 2006 03:29 PM
