Brake lights and turn signals not working
Hello! I drive a 1992 volvo 240.
Recently, my turn signals and brake lights haven't been working. When I use my turn signal, the lights on the console don't blink either. However, every once in a while when I turn the car on, they work again. Any ideas what could be causing this?
TIA
TIA
on any 240, *ALL* fuses should be replaced with Flosser copper/brass ceramic fuses ASAP. the fuses sold in car parts stores are tinplate and subject to oxidation and failure. clean the fuse contacts, too, with something non-abrasive. I use a soft clean pink pencil eraser as that takes off corrosion without stripping the plating off the metal.
