A/C Problems Climate Control Module
Some time ago I found a Post on which harness conections on CCM board had to be resolder when A/C will not come on. I can bump the side of dash near Module and it will engage compressor. I took it out today and resoldered the one under the vac hoses, like I did before figuring this would work again, but when I put all back together I still have to bump dash for it to come on.
Does anyone remember this old post. Seems it had pictures and all. Thanks for any Help
92 940 Still running good.
Thats whats so cool about Forums and internet an all. I plan to get out tomorrow and disassemble it again. It took a little while today to remember and to re-figure out how to get CCM out.
For guys like me who only work on their own stuff its good to know to use a 1/2" wide blade like butter knife to start on right side of plastic dash cover, some silicone spray used sparingly could help too. Gently message thin plastic from around CCM working from right to left. Once you get it loose you'll see how easy it is. Remove 4 screws and bend those metal tabs down and CCM pulls right out. Use small screwdriver to get electrical and vacume hoses off. Can sure save a lot of money with this one.
Thanks Administrator for your help
thejobark
Jan 30, 2007 01:30 PM
