can't stop heat in car
Old Aug 29, 2007 | 04:26 PM
CHRIS100671's Avatar
Default can't stop heat in car
Hey. I have a problem. I can't stop heat from blowing into my car. I have all the controls turned off and it still blows heat. It's a 1990 740 volvo gl wagon. Since the air doesn't work right now this is not a good problem. Any ideas?
Old Aug 29, 2007 | 05:08 PM
funnyguy44444's Avatar
Default RE: can't stop heat in car
Your problem is the heater valve. Mine had the same problem. Sometimes when they get old there is a rubber piece in there that wears out. It is located next to the drivers right foot behind that plastic pannel (at least on my 240 it is yours might be in a different place). You should be able to go down to the junkyard and pick up a new one for 5 bucks. They are kind of a pian to take out (make sure you unhook the heater hoses from the other side of the firewall before you take the one out of your car or you'll end up with antifreeze all over your floor)
Old Sep 10, 2007 | 11:07 PM
kotty's Avatar
Yeah, your problem is the heater valve,sometimes it also has the potential to create a lot of heat.And while having a high temperature within the engine makes it efficient, heat can build up over time if left unchecked and can possibly result to overheating problems. And when the engine overheats, it makes the engine detonate and lose power under load, damaging various engine parts such as pistons and rod bearings in the process. Same with my volvo 240 radiator.
GaVolfan
Feb 20, 2015 01:20 PM
pnhons
Nov 20, 2011 05:26 PM
MC92
Sep 8, 2011 11:42 AM
hskim
Dec 12, 2008 10:45 AM
revriff
Mar 10, 2008 07:35 PM
