changing rear wheel bearings volvo 940SE Greasing
Old Jan 5, 2017 | 06:58 PM
volvodicus's Avatar
Default changing rear wheel bearings volvo 940SE Greasing
Hej!
Soon i want to start changing the rear wheel bearings on my volvo 940, its a standard axel, so the bearing set comes in 4 parts; 2 seals, 1 retaining ring and 1 bearing. Now i have a hydrolic press and a weekend to spend, it seems i can fix it. the question i have now is if i need to grease the bearing as much as possible without having the grease being mixed up with the differential oil;
does the inner seal keep out the the diff. oil? can i grease the bearing extra with bearing grease?
Also, if i use the hydrolic press and an appropriate sized pipe to press on the new bearing are there any chances the retaining ring can brake?
o/ kind regards,
Thomas
Old Jan 6, 2017 | 06:00 AM
act1292's Avatar
Have a look at this thread. It describes the whole procedure. It's for a 240 but if you have the live axle in your 940 I think it should be the same.
https://www.brickboard.com/RWD/index...647&show_all=1
orb
Aug 19, 2015 08:31 AM
CPVolvo
Dec 22, 2011 03:49 PM
537playing
Sep 7, 2010 06:15 AM
dutch connection
Feb 13, 2010 08:39 PM
bigtombbq
Dec 1, 2008 03:29 PM
