Clunk from rear end
Old Apr 2, 2006 | 09:58 PM
RedBrick's Avatar
Default Clunk from rear end
I have noticed the if I am sitting in the car at idle and I shift the auto trans into reverse, or I shift it from neutral to drive I hear a clunk noise which sounds like it is coming from the readend.
I have noticed recently that when taking off from a stop I get a clunk when shifting from first to second, but all other gears shift ok.
Could this be a bad rear-most u-joint?
If so should I replace all of the u-joint and center bearing and trans mount?
Can the average person perform this task.
Thanks
RedBrick
http://pg.photos.yahoo.com/ph/fap_su...e2.jpg&.src=ph
Old Apr 3, 2006 | 12:19 AM
Red XC's Avatar
Default RE: Clunk from rear end
Try replacing the tranny mount! It might be worn!
Old Apr 3, 2006 | 09:06 PM
Check the mount it is easy to look at and see if it is sitting on the crossmember.
Try turning the drive shaft in park and see if you feel the play in the driveshaft.
lilbanjoe
Mar 16, 2010 12:18 PM
Psaboic
Sep 27, 2009 08:56 AM
Bruno937
Mar 8, 2009 12:41 PM
turbosteve
Suspension
Jan 18, 2009 01:38 PM
Padrea
Oct 28, 2008 10:15 PM
