It comes and goes!???
Old Oct 20, 2008 | 02:40 PM
hairyg's Avatar
Default It comes and goes!???
Have a 1991 740. After driving it for a few minutes, there is the worst shimmy in the steering wheel that last for awhile several minutes/miles. Then it goes away and can return. Don't know if it is related or separate, but, I also have a dramatic pull to the right when I break. Bad tire? Alignment? Balance? Caliper? The tires are old and about to be replaced.
Unrelatedly, how do I turn off the service light with the button on the dash?
Thanks for all suggestions!!!
Old Oct 20, 2008 | 02:45 PM
Default RE: It comes and goes!???
I would check everything in the front end.
Also for the service light you should have to pull the rubber grommet out and use a small screwdriver to push the button in with the key on and it should reset it.
Old Oct 21, 2008 | 10:05 AM
dads 740 turbo's Avatar
Outer Tie rod ends, Inner Tie Rods, and maybe your Calipers are no longer floating and stickingand are in need of replacement........or a broken Belt in One of the Tires, sometimes after a few hardpot hole hits the Belts inside a tire can De-Laminate from inside the tire.......Like TECH Said check EVERYTHING in Front End...
Old Oct 22, 2008 | 06:54 AM
hairyg's Avatar
Thanks, gentlemen, for the advice! Will check things out!
JoeSchmo
Dec 21, 2013 10:34 PM
berrymcb
Dec 7, 2011 10:48 AM
volvolini
Mar 22, 2010 10:03 PM
