Coolant Flush
Old Oct 14, 2015 | 10:14 AM
IFGD's Avatar
Default Coolant Flush
I'm going to flush my coolant this weekend in my 240. Is it best to drain the old stuff from by pulling the lower radiator hose or is it better to use the drain on the block?
Any other suggestions for someone who has never done this before?
Old Oct 14, 2015 | 10:17 AM
lev's Avatar
lev
You have to drain the radiator from the hose, the block from the drain on the block. Watch for air pockets afterwards, they can be tricky!
Old Oct 14, 2015 | 10:23 AM
IFGD's Avatar
If I pull the lower radiator hose it seems like coolant is going to go all over that cross member right below it. Do you just have to deal with coolant everywhere?
Old Oct 14, 2015 | 10:26 AM
IFGD's Avatar
Also, is there a good write up or video tutorial on how to do this for a 240? I can't seem to find one.
Old Oct 14, 2015 | 01:33 PM
lev's Avatar
lev
The radiator MAY have a drain plug... Otherwise, the messy coolant all over is the only way. Draining a coolant is pretty straight forward thing--Youtube may have something.
Old Oct 15, 2015 | 06:49 AM
act1292's Avatar
I usually flush the system by first draining the block then the radiator. The block drain you can attach a hose and run it to a bucket. I drain the radiator by removing the hose from the water pump. I put a big bucket right underneath the water pump, remove the hose and point it down into the bucket.
I haven't seen a Volvo or Nissens radiator with a drain plug.
Old Oct 15, 2015 | 06:50 AM
IFGD's Avatar
See, that's the thing. The radiator sits on top of that cross member. There's no way to access the bottom of the radiator. THIS car seems to be different than most that I've seen in regard to this. That's why I was looking for a write-up on 240s specifically. I can't seem to find one. It doesn't exist on youtube.
If I pop that lower hose off, antifreeze is going to make a huge mess (more than it normally would). I still can't believe that no one else has had this question and/or figured out a way around it... or made a video.
Old Oct 15, 2015 | 06:52 AM
IFGD's Avatar
We were writing our posts at the same time.
Hadn't thought of taking the hose off at the WP side. It seems so obvious. Thanks!
patrm
2001-2013 model year V70
23
Mar 5, 2014 08:43 PM
shop2
Nov 1, 2011 08:56 AM
Glenn B
Feb 19, 2008 04:57 PM
jmaslanka
Sep 25, 2007 11:41 AM
RPMCanes
Sep 20, 2007 11:55 AM
