Coolant Temp Sensor
Old Feb 16, 2006 | 01:29 AM
Snooky's Avatar
Default Coolant Temp Sensor
Have a question about the lead that goes to the temp sensor. I have 5 volts on one side of the lead, and 4.5 volts on the other side of the lead. Seems strange that I would have voltage on both sides of the lead. I thought one side would be reference voltage, and the other would go to the computer so shouldn't be much of any reading on the computer side. I tested with key on and the lead disconnected. 1990 Volvo 740GLE DOHC motor. Cheers
Old Feb 16, 2006 | 11:38 AM
wojeepster's Avatar
Default RE: Coolant Temp Sensor
Test with lead connected. Then you will get a voltage drop over the sender. You will get a larger drop when the engine is cold (higher resistance) and a lower voltage drop when warm (lower resistance)
blackbrick
May 7, 2011 01:46 PM
cisopen
Sep 20, 2010 05:25 PM
angel308
Jan 23, 2008 06:36 AM
vcolper
Nov 1, 2006 10:20 PM
