Correct way to apply thread lock.
I would like to know if you have to wait for the thread lock to dry on a bolt before installing it or can I install the bolt into place with the thread lock wet. I am replacing the sway bar links and want to make sure that the bolts going into the cast iron arms don't work their way loose over time.
dads 740 turbo
10-15-2008 02:42 PM
apply, ball, components, correct, dry, install, installing, joint, lock, screw, suspension, thread, threadlock, type, volvo
