cylinder #1 not firing
Old Nov 26, 2013 | 07:33 PM
lynleinc's Avatar
Default cylinder #1 not firing
Would like some opinions. 86 240 dl wagon b230 engine: Cylinder #1 has stopped firing. Mechanic changed spark plugs, distributor / cap and wires. Did not change coil. No improvement. Engine does need new wiring harness. Engine does not smoke (nor has it ever) or seems to have any anti freeze in the oil (vice versa). Going to be getting compression test very soon. Other threads seem to point to valves, rings or entire head needing to be replaced. Does anyone think that it may be electrical, especially if it fails compression test?
Thanks in Advance
Gary
Old Nov 26, 2013 | 07:58 PM
the only thing that distinguishes #1 from any other spark plug is the spark plug wire, and terminal in the rotor.
if it fails a compression test, thats purely mechanical. piston rings, valve, head, gasket, pick one.
Old Nov 26, 2013 | 09:02 PM
lev's Avatar
lev
"Stopped firing"? Firing is a misnomer, and only related to ignition, which you addressed, so if you still have a miss, compression or leakdown test is called for. Compression test is not Pass/Fail. Its results have to be evaluated. Based on the readings of the test, you can see your options, if it's done correctly. With bad wiring though, all bets are off... It may affect one or more injectors... How bad is the wiring?
Post the comp. test readings, go from there.
Old Nov 26, 2013 | 09:17 PM
all 4 injectors are wired together, so if you suspect the wiring to one injector, you can swap it with an adjacent one.
Old Nov 27, 2013 | 05:13 AM
act1292's Avatar
I'm just curious - how have you determined that cylinder 1 is not firing (as opposed to one of the other cylinders)?
Old Nov 27, 2013 | 08:00 AM
jagtoes's Avatar
If you hook up an inductive pick up timing light to Cyl #1 spark plug wire does it flash? Simple test also if you pull the plug is it fuel fouled. Once again it's either a fuel or spark issue unless you have 0 compression.
Old Nov 27, 2013 | 08:18 AM
A lot of people pull spark plug wires off of the plugs one at a time until the idle changes. If you pull a wire and have NO change, you found your dead cylinder.
What I don't understand is why a mechanic would NOT immediately check compression when diagnosing a miss? It only takes a minute, pull the plug, stick the gauge in, pull the ignition & fuel and crank.
Old Nov 30, 2013 | 02:07 AM
no feedback from the original poster?
sigh.
Kim Gregory
Mar 6, 2013 08:40 AM
Untuned
Apr 9, 2011 07:37 AM
pikey
May 10, 2007 01:34 PM
sambagis
Jan 24, 2007 09:03 PM
J Taylor
Apr 12, 2006 09:31 PM
