Dead Speedo on a 92 240 Wagon
Old Aug 10, 2006 | 12:29 AM
psychoCHIPMUNKK's Avatar
Default Dead Speedo on a 92 240 Wagon
No, not the bathing suit.
On a long drive across the country my speedo and odometer died on me. It happens over a great distance, like a few hundred miles. At first, the speedo would not read speeds of over ~60 mph, then it went to 50, then it just stopped working all together. Now no matter what speed i go the needek doesn't even twitch. Any idea what i should check?
Old Aug 10, 2006 | 12:38 AM
Default RE: Dead Speedo on a 92 240 Wagon
Does the ABS light come on when it happens?
The ABS sensor in the rear controls the Speedo signal.
Old Aug 10, 2006 | 01:16 AM
No, I'm pretty sure it doesn't have ABS. I know it has the light for it because it comes on when i first start the car, but i know i've locked up the wheels a few times. Maybe that's the problem...
Old Aug 10, 2006 | 01:19 AM
Maybe the Rear Differential sensor is bad.
Old Aug 10, 2006 | 01:36 AM
How would i go about checking it?
Old Aug 10, 2006 | 08:39 PM
Usually you can get a Reading with an OHM meter with the Car up in the air safely.
If you get a reading spinning the tires it should be fine. If you don't get a reading then it is bad.
Also check the wires good known to break.
Old Aug 12, 2006 | 01:52 AM
nadernur's Avatar
same thing happened to me i just went to the junk yard and pulled one off another volvo (carful not to strip the allen bolt) and popped it in mine and it worked like a charm. But my cruise control didnt work so i think that might be the switch itself!
Old Aug 12, 2006 | 02:01 AM
Ok, i'll be sure to check it, where is it located?
Old Aug 12, 2006 | 02:21 AM
nadernur's Avatar
On the back of the rear differential it has a wire coming from a small sensor, about one square inch. It has one Allen wrench bolt (again be careful not to strip it) and that’s just pull it out disconnect the wires and put in the one from the junk yard. I couldn’t find anyplace that sold it new! Good luck!
dobrosailor
Mar 5, 2013 05:23 PM
gstrussman
Sep 7, 2012 11:53 AM
aokp
Sep 3, 2011 10:07 AM
DrHicks
Aug 13, 2011 10:30 PM
texan_176
Oct 25, 2009 07:05 PM
