distributor
Old Mar 14, 2006 | 11:26 AM
gman47's Avatar
Default distributor
I still need to know how to check a magnetic pickup dist. for a 89 740 turbo.
Old Mar 14, 2006 | 09:38 PM
Default RE: distributor
Im still working on it. I have specs to check everything else but the Dist.
Old Mar 15, 2006 | 09:04 PM
wojeepster's Avatar
generally if it is a two wire pickup it puts out an ac voltage (gm) if it is a three wire pickup then one wire is power (either 5v or 12v), one wire is ground, and one wire is out put (usually 5v). You can test the output wire with a logic probe. it should flash on the output while cranking.
iwantansti
Nov 18, 2007 09:16 PM
HotCoil
Mar 17, 2007 08:55 PM
2003F250
May 4, 2006 08:39 PM
gman47
Mar 11, 2006 11:16 PM
Volvorator
Mar 3, 2006 09:26 PM
