Drive Shaft Not Secure
Old Mar 12, 2008 | 10:18 PM
dman777's Avatar
Default Drive Shaft Not Secure
My 89 Vovlo 240 DL had a transmission leak. The fluid leaked all over the roundrubber ringthat is in the middle of the car that secures the drive shaft and keeps it from bouncing around. The rubber got corroded from the fluid and the drive shaft isn't secure. I don't really have the money to fix it right now. Is this something that can wait awhile or am I going to mess up my car driving it like that?
Old Mar 13, 2008 | 07:48 PM
jonesg's Avatar
Default RE: Drive Shaft Not Secure
I believe the fix is less than $25.
Pull the shaft, drive the old one off, drive the new one on.
I've seen the carrier bearing with boot on ebay for $18.
Old Jun 2, 2008 | 08:51 AM
dman777's Avatar
This guy at work told me that I would have to pull out the drive shaft in the transmission to do it. I still haven't gotten the money to fix this yet. I noticed that my Gear shift stick vibrates hard when I go over bumps, is this because of the driveshaft bearing boot is worn making the draft shaft vibrate?
Old Jun 4, 2008 | 10:33 AM
tedv's Avatar
By "isn't secure", if the donut is deteriorated that badly, you'd get a bad viabration on acceleration, may be some clunking as the driveshaft bounces around, NOT bouncy shifter-that's another matter of bushings there. And you maybe able to get the donut replaced without the complete removal of the driveshaft.
s60propshaft
Jan 15, 2023 06:59 PM
Newport_j
Dec 5, 2014 03:47 PM
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
Volvo-Profess
Jan 14, 2011 05:55 PM
rolling2
Sep 25, 2010 12:59 AM
