dumping raw fuel into cylinders
Old May 1, 2005 | 11:34 PM
Lee NC's Avatar
Default dumping raw fuel into cylinders
I have a 1987 240, over 300,000 miles. Has been running rich until warmed up, finally would not start. Pulled plugs, turned engine over, spitting raw fuel out of cylinders. Is there a common cause for this? Help! Thanks..........
Old May 2, 2005 | 01:16 AM
Default RE: dumping raw fuel into cylinders
Make sure the fuel pressure regulator isn't bad.
Also do you have spark?
Old May 3, 2005 | 12:49 AM
Lee NC's Avatar
I do have spark but it is not very hot. I have not checked fuel pressure regulator. How do I check it? Thanks much..........
Old May 3, 2005 | 11:08 AM
Most of the time when they go bad they dump fuel into the intake manifold.
Take the vaccum line off the back of the regulator and see if it is filled with gas.
You could also have a problem with the engine speed sensor.
Smittys80
Oct 24, 2014 06:35 AM
agardin10
Dec 27, 2010 11:01 AM
hots60r
Dec 26, 2010 12:57 PM
Beemer2002
Dec 31, 2009 10:57 AM
