Easy Timing Mod
Old Sep 28, 2017 | 03:54 PM
Nichals's Avatar
Default Easy Timing Mod
Just wondering if anybody on here has tried the mod to the ignition controller by jumping pins 18 and 19 in order to modify the engine timing?
Anybody have any good results?
What do you think about adjusting the timing on red blocks?
the mod in question:
* By grounding pin 18 you will get -3° (retard).
* By grounding pin 19 you will get -6° (retard).
* By grounding pin 18 and 19 you will get +3° (advance).
Old Sep 28, 2017 | 04:22 PM
Oodlemi's Avatar
Are you trying to make up for more boost? Otherwise, why are you messing with the timing?
Old Sep 29, 2017 | 01:27 PM
Nichals's Avatar
I want to change the torque curve to be at the lower RPM range. I don't take y car on the highway often but am in a lot of stop and go traffic, so I have room to sift it back a little.
Old Sep 29, 2017 | 03:18 PM
which ignition controller is this? they used a lot of different ones in different cars, years.
Old Sep 29, 2017 | 04:01 PM
Nichals's Avatar
Originally Posted by pierce
which ignition controller is this? They used a lot of different ones in different cars, years.
ez116k
MarkattheOSU
Oct 12, 2012 07:24 PM
appatula
Jun 8, 2010 09:24 AM
VolvoPower850r
Nov 27, 2009 07:40 PM
dads 740 turbo
Nov 5, 2008 09:29 AM
AlexR
Oct 11, 2006 09:59 PM
