Easy Come Easy GO+ ABS ?'s
Old Oct 11, 2006 | 07:37 PM
AlexR's Avatar
Default Easy Come Easy GO+ ABS ?'s
Well after fixing the last of the issues with the 97 960 i just bought the inevitable happened. I was side swipped by a beamer and sent up a cement divider where i then landed the nose on and bent the frame into a shape resembling a L. TOTALED
Now for the good news. After some research ive decided to mount the powertrain in my 84 242ti witch has been waiting for a motor since a 27psi boost spike over the summer.
Im going to use the 960 OEM ECU's and sensors
My question is if anyone knows how i would go about getting around the issue of it going into a non ABS car?
Any thoughts?
Old Oct 11, 2006 | 09:22 PM
Default RE: Easy Come Easy GO+ ABS ?'s
You should be able to install the motor and trans. without the ABS module and use the existing cluster for the 240. If not then try to find and transplant a Rear out of a 740 with ABS.
Old Oct 11, 2006 | 09:46 PM
AlexR's Avatar
ORIGINAL: tech
I planed on take a 740 abs rear and fitting the 960 tone ring. As that is the only way i know of to get a correct speed/tach measurment.
Mainly what i was asking {witch i belive you answered} is can i just not install the abs module with out any problems.
Thanks
Alex
Old Oct 11, 2006 | 09:59 PM
It will be a try and see.
It might need it for the transmission to shift properly.
sbanks
May 21, 2010 09:47 AM
hjloap
May 19, 2010 11:55 PM
dads 740 turbo
Nov 5, 2008 09:29 AM
acorales
Mar 26, 2008 09:46 AM
steveroe
Jun 27, 2007 09:38 PM
