engine dont start but rotates
Old Aug 15, 2005 | 11:27 PM
highspirit78's Avatar
Default engine dont start but rotates
[b][:@]hello alll i have a ? i have a 1987 240 gl and the car was out of time and it was just out back in time and now the engine does not want to start the only thing it does is rotates. it has a new cap wires plugs rotor air mass censor timming belt. but when i hook up the test light to the fuel injegtion the light never came on but when u go to fire the car u can smell the fuel now my ? is why is that? bc the spark plugs are getting spark and fuel guys i need some help on this bc im s single mom trying this on my own plz any help thanks
Old Aug 16, 2005 | 01:03 AM
Default RE: engine dont start but rotates
Do you get any power at all at any of the injector wires?
The injectors are a negative pulse to fire.
Old Aug 21, 2005 | 01:25 AM
matthewensey's Avatar
If you smell fuel, then the plugs are not getting spark, most likely. First I'd look at the coil, buy one and try it. If it doesn't work, take it back and get your money. I'm thinking the coil is the problem. Based on smelling fuel, you can eliminate all fuel possiblities. How long has the gas been in the tank? If it's been years, you need to get fresh fuel in there. I'm not sure if draining the tank is necessary, I've never had to do that before. If the fuel is old, you may want to ask the person at the auto parts center what you can do to stabilize it. Like I said, I've never had to deal with that before. Good luck, I always try to help out a single mom, I was raised by one.
Matthew
SPANK
Aug 11, 2012 07:35 PM
sam2010
Sep 25, 2010 07:12 PM
WINDSHIELD
Apr 16, 2008 12:54 AM
oxmanwi
Nov 28, 2006 10:10 PM
drpdwgn
Nov 9, 2005 07:36 PM
