Engine Stalled - Metallic Grinding Noise
Old Sep 29, 2009 | 05:20 PM
Kivstev's Avatar
Default Engine Stalled - Metallic Grinding Noise
Greetings,
A few days ago while driving my '93 940 Turbo wagon with 205K. I noticed a loud metallic scraping noise coming from the car. It sounded exactly like one would expect if the muffler was dragging. However, looking under the chassis I found nothing. Today I heard the same noise, checked underneath once again and nothing was hanging. I got inside and drove away, heard the 'metal scrape' noise and the car stalled. I am unable to start it, but the engine does turn over.
My best guess is a timing belt issue? From research here I also understand that my vehicle has the B230FT engine which is non-interference.
It's now at the local tow shop awaiting inspection 'most likely Thursday'. Any educated guesses at what the problem might be? I've had no other mechanical problems/symptoms. Thanks.
Old Oct 7, 2009 | 05:12 PM
Kivstev's Avatar
Turns out it was a broken bolt in the tranny/flywheel area that hit and knocked out a sensor in that area. That was the cause of the metal noise. Somehow my timing belt also jumped. Glad it's not an interference engine...
V70-T5
Jun 20, 2010 06:58 AM
pgrossjr
May 17, 2010 06:20 AM
erinsvolvo
Feb 19, 2010 09:17 AM
flamejet
Jan 4, 2010 06:20 PM
mauriciogalvao
Nov 28, 2008 06:12 PM
