Extra tube on steering rack
Old Sep 25, 2009 | 04:52 PM
act1292's Avatar
Default Extra tube on steering rack
I recently purchased a 1990 Volvo 240 DL sedan and have been going over it fixing up a few items. While replacing the ball joints I noticed that one of the steering rack boots was torn and needed replacing.
I ordered a couple from FCP Groton and found that the ones delivered are slightly different. I have a CAM/TRW rack so I ordered the ones that have the small end.
The difference is on the large end that connects to the rack. The old one had an extra hole that connects to a tube that runs along the rack to the opposite boot. I suspect that this tube simply balances air pressure between the boots but I'm not sure.
The replacement boots have no such hole for this tube. Does anyone out there know if I can just discard this tube and use the new boots or should I return them for OEM ones?
Old Sep 25, 2009 | 05:38 PM
TURBO 245's Avatar
Return them and order these from eeuroparts.com
270881k LH
270882 RH
Dan
Old Sep 25, 2009 | 07:51 PM
act1292's Avatar
Thanks Dan. That seems to be the correct boot for my rack. The rack numbers match up.
Placing my order tonight.
Thanks again.
timmins
Sep 28, 2022 02:00 PM
intence
Mar 3, 2008 08:40 PM
katiejoyful
Dec 12, 2007 04:49 PM
kwb131
Nov 19, 2006 03:49 PM
amandac
May 27, 2005 12:21 AM
