Friend found an '84 at pick-a-part. What to salvage?
Old Dec 18, 2012 | 04:15 PM
fourbi4rox's Avatar
Default Friend found an '84 at pick-a-part. What to salvage?
I just purchased an 85 240 DL with 240,000 on the odo. It runs great, just passed CA smog, everything works in the car and it recently got a radiator flush & new fluids all around, including trans, diff & PS. The only thing that needs attention is the rubber surrounding the center support bearing on the driveshaft. I will be replacing this, along with changing front pads & maybe doing plugs n wires since the insulation is looking wethered.
I just got a call from a friend today who was at the local pick-a-part junkyard and came accross an 84 DL that he says is fairly intact from the motor back (was in front-end collision). I'm gonna leave early from work tomorrow and go salvage some odds and ends: relays, fuses, switches, plastics, etc.
What else should I take that I will likely need in the future? Should I bother with the fuel pump(s) or just buy new when mine fails?
Old Dec 18, 2012 | 07:37 PM
sparky319's Avatar
The things I always end up replacing is the tail light lenses, center console plastic, and antenna. And trim molding clips. Also, inside door trim pockets, and glove box latch. Enjoy that car.
Old Dec 19, 2012 | 10:48 AM
fochs's Avatar
Default Bring a sack.
I'd Take the ECU, AMM, fuel pump/ system relay, Harness if in good shape, O.D. relay, fan switch, A/C switch, Plug wires if the continuity is ok, interior trim clips, throttle switch, air hose from AMM to throttle body if intact and for sure all lenses, as many bulbs as I could carry, spare headlight and a coil. And idle control valve. And yeah, Id pull the fuel pump and the connector hose and fittings from the pump to the filter. Also any rubber parts what seem new, fuel pressure regulator.
For sure the fuel pump relay and ECU, though.
Hose clamps big and small if they are sturdy and awesome and original equipment.
Old Dec 19, 2012 | 12:34 PM
are 84 and 85 both the same version of LH-II ? I believe 84 is too early to be LH2.2, but I dunno 85. LH2.2 was used in 86-88 at least.
Old Dec 19, 2012 | 04:18 PM
fourbi4rox's Avatar
Thanks for the tips! I'm not sure which Injection/Computer system I have in my '85, but I grabbed the ECU from the '84 anyway since they didn't charge me for electrical stuff. Are the ECU's in the manual trans cars different than the ECU in an automatic?
Heres what I hauled in: Trailer Hitch, trailer light converter thingy, hi pressure fuel pump, regulator, airbox assembly w/maf, ECU, ign. control module, coil, battery & spark plug cables (look brand new), alternator, starter, PS pump, engine brackets & pullies, tail light lenses, interior dome lite, climate control switches, instrument cluster, steering column/turn signal switches, all the relays and fuses, kick panels, interior door plastics & a coffee can full of hardware & clips.
$90 for the haul. Not bad seeing that i was looking at spending over $200 for a new hitch
Old Dec 20, 2012 | 11:24 AM
swiftjustice44's Avatar
84 is LH 2.0, 85 should be LH 2.2 unless very early model...so the ecu's are different as are the AMM's. Sounds like you made a good harvest for $90!
volvony2
Nov 18, 2011 12:09 AM
ibified
Aug 19, 2010 10:18 AM
bearshark
Dec 9, 2009 07:53 PM
dkooda
Mar 16, 2009 07:41 PM
msm15
Sep 10, 2008 10:45 PM
