Fuel Guage reads empty?
Old Nov 1, 2012 | 10:33 AM
xsadie19's Avatar
Post Fuel Guage reads empty?
I see this can be a common problem, my fuel guage is stuck on E...
Anyone know what I can do to fix it?
Old Nov 1, 2012 | 01:44 PM
well, it could be A) the sender unit in the tank, B) the wiring between A and C, or C) the gauge in the instrument panel.
B) is actually the most likely, especially right where it leaves the gas tank.
Old Nov 2, 2012 | 06:22 AM
act1292's Avatar
As Pierce says, most likely it is where the wire enters the tank. Take a look at this page
In the Tank - 240 Volvo Tank Pump and Sender
It has a picture of where the hermetic seal has come loose on the sending unit due to rust (note that it is the same site describing the blower replacement. Great site). I have had this same problem on two of my cars. If this is the point of failure then most likely your in-tank fuel pump is not working as well. The site above describes how to diagnose all of this.
If you find that your sending unit needs replacement, take careful note of the replacement unit wiring. As the site above notes, they are usually wired incorrectly.
Good luck
CHASBAKER
Apr 11, 2020 08:30 AM
EivlEvo
Dec 1, 2015 09:36 AM
a4ty4d
Jul 22, 2010 10:49 PM
ReneVersteeg
Apr 4, 2005 08:58 PM
