Fuel hose
Old Jan 16, 2010 | 03:32 PM
dobrosailor's Avatar
Default Fuel hose
As part of trouble shooting another problem I decided to replace my fuel filter. This car is a NY car ('93 940 non turbo) so all the fittings dissolved and the fuel hose is cracked. I need to replace the hose and was going to install a generic fuel filter. Anyone know what pressure is in the fuel system. The hose installed has a plastic liner which I imagine is for high pressure or is it just Swedish overkill. Can I go to the autoparts store and purchase generic hose and clamp it to the hard line from the tank or does it take high pressure fittings etc.
I have loved this car for years - best car I have had but I'm about ready for a bonfire...
Thanks for all your comments...
M
Old Jan 16, 2010 | 09:47 PM
Typhoon's Avatar
You need to ask for fuel injection line, take a sample to get the right size. Also buy some decent hose clamps.
There will be a fuel filter on the car, I suggest you find a manual and fit a new filter in the existing location.
Are you using alcohol blended fuels?
Regards, Andrew.
Old Jan 17, 2010 | 08:54 AM
Default I run what ever is out there - my wife's car
The old fuel filter was rusted with fittings completely salted out. The whole thing is going to be one piece for eternity. SO I will put an aftermarket filter in the same position but the fuel lines also need replacement.
Thanks,
M
Old Jan 17, 2010 | 01:21 PM
1981 240 dl's Avatar
You can also get the fittings at most auto part stores pretty cheap, I did for my 81 dl as they were pretty much fused together. I bought the filter and asked for the fittings and they had them in stock. They kinda looked like old school brake line fittings one with a large o ring shaped metal ring with a special bolt with two brass washers. The filter cost alot more than the fittings.
chachouu
Apr 30, 2015 10:47 AM
Ricardobs84
Jun 22, 2013 09:46 PM
klart
Jun 7, 2011 06:53 AM
zerochills
Aug 19, 2009 01:31 PM
rationull
Oct 30, 2006 03:40 PM
