Fuel Injectors not getting power
Old May 6, 2023 | 02:38 PM
Phewtorr's Avatar
Default Fuel Injectors not getting power
Hello again everyone, I have a 1986 Volvo 244 DL that is not running and seems keen on staying that way. My fuel injectors are not getting any power and I don’t know where to go from here. It’s an LH 2.2 and they ecu and relay are sending it power/ signal and it’s not getting any of it. Any help would be appreciated, thank you.
Old May 9, 2023 | 09:49 AM
Parlee240's Avatar
There are two sets of black wires from the injectors connecting to grounding points on top of the intake manifold. Check those grounding points and cleaned them to ensure good contact. Hope this helps.
Old May 10, 2023 | 06:28 PM
Vinnie4.4's Avatar
if you need wiring diagram send me vin number and I will see what I can do to help
Old May 11, 2023 | 08:27 AM
Phewtorr's Avatar
The VIN is YV1AX8842G1157971, thank you for your help
Phewtorr's Avatar
Thank you for the advice but I tried that already and no dice
Old May 11, 2023 | 01:16 PM
Parlee240's Avatar
Check the white-color fuse holder attached to the left fender just aft the battery. There is a 25v ATC blade fuse that is used for engine management which might affect fuel injectors. The holder is in a vulnerable position that is somewhat exposed to moisture.
Syndave
Apr 29, 2020 06:30 PM
atwolfe10
Nov 6, 2016 03:18 PM
floz313
Jul 17, 2014 07:36 PM
Tony Villa
Oct 4, 2012 06:31 PM
J Taylor
Apr 12, 2006 09:31 PM
