Fuel Injectors Not getting Power
Old Jul 17, 2014 | 04:09 PM
floz313's Avatar
Default Fuel Injectors Not getting Power
Ok i own a 1993 940 volvo sedan and as i was driving the car and it just shut down on me the car turns over when you turn the key switch well we had taken the car to a mechanic shop and he said the fuel pump was good and im getting gas so then he said its one of two problems the Engine control module witch he would fix and program to my car for 415$ or it could be the injectors not getting power and he was 90% sure it was the injectors so how could i go about fixing this problem and what would i have to replace? thanks
Old Jul 17, 2014 | 06:08 PM
busdude2's Avatar
The injectors recieve their pulse signal from the ecm. Is the ecm getting battery constant power,(keep alive memory) and ignition power (wake up) ? Have all the fuses been checked ? Sounds like a power supply issue. Fuses,or wire harness plug ect. ?
Old Jul 17, 2014 | 07:36 PM
lev's Avatar
lev
Or it could be something like the crank pos. sensor, which is what I'd look at first... ECM, not likely. Get someone who knows these cars to help you with it-this mechanic doesn't seem to be that guy...
Vmax
Apr 7, 2014 07:42 PM
scrap88
Apr 7, 2010 09:23 PM
pikey
May 10, 2007 01:34 PM
JohnG
Apr 1, 2007 09:39 PM
robmcconnell
Nov 6, 2005 09:25 PM
