Fuel line leak
Old Dec 1, 2013 | 11:05 PM
CanadianDiesel's Avatar
Default Fuel line leak
I have a leaky line near the fuel tank. Can the original steel line be replaced with rubber?
And can I get away with only replacing that short section? (running from the pump to the tank?
thx!
Old Dec 2, 2013 | 12:21 PM
make sure you use fuel injection hose, and not plain gas line. do not use those worm gear common hose clamps, use proper FI clamps that look like...
as far as how much to replace, kinda depends on why its leaking. me, if the car was a keeper, I'd be considering using brake line tubing and fabricating new metal lines.
Old Dec 4, 2013 | 10:35 PM
Noted. The current line is rotted (from road salt i would assume) near the fuel tank.
I'm thinking the 740 will be a keeper…she'll need some work though, that's for sure
Old Dec 4, 2013 | 10:54 PM
You could use the copper-nickel tubing (cunifer) thats used for brake lines as a fuel line. its stainless, doesn't corrode, its quite ductile, and very durable and pressure safe. it doesn't fatigue and crack under vibration like copper or brass tubing would. Volvo has used this for their brake lines since 1976.
stuff like this,
5/16"/8mm Fuel/Hydraulic Line
Old May 18, 2014 | 07:17 PM
Andre_240's Avatar
hi Pierce,
if there's a pin-hole sized leak on a metal line, do you think the suggested clamp could cover and seal it ?
thanks!
Old May 19, 2014 | 05:22 PM
240-FAN's Avatar
Originally Posted by Andre_240
hi Pierce,
thanks!
jbweld if you have to for short term. Other wise no, clamp wont work`
Old May 20, 2014 | 08:11 PM
Andre_240's Avatar
gas tank jbweld did the trick on the fuel line... thanks!
Old May 20, 2014 | 08:23 PM
carry a large fire extinguisher rated for gasoline fires at all times.
Old May 21, 2014 | 06:32 AM
240-FAN's Avatar
https://www.osha.gov/SLTC/etools/eva...es/cutaway.jpg
as an FYI . Glad the jbweld worked. I wouldnt trust it on a long term basis
Old May 21, 2014 | 07:25 PM
Andre_240's Avatar
no! and I will carry the fire extinguisher!
thanks!
UlsterBoy13
Oct 8, 2014 09:57 AM
Galaxy850Sunny
Jun 23, 2014 04:56 PM
Olga240
Apr 9, 2013 02:22 PM
mjsparky363
Apr 27, 2010 04:38 AM
TungstenT2
Sep 30, 2009 08:55 AM
