fuel line leak
Old Apr 25, 2010 | 09:11 AM
mjsparky363's Avatar
Default fuel line leak
Good morning all. A few weeks ago I had the fuel rail etc. apart to change the oil trap. This morning I had the fuel line pop off the top of the regulator and spray about 1/2 tank of gas all over. On my 03 there is a light blue ring that I thought snaped into the fuel line from the fuel pressure regulator side. I had this piece snapped in and all seemed fine (2 weeks/200miles) until this AM. This blue piece was just laying on the FPR when I disconnected things 2weeks ago and when I reinstalled the fuel line I put the blue clip up inside the female coupler. I have searched high and low for a picture but all that I have found show the blue clip on the fuel tank side of the fuel line where as mine in on the FPR/fuel rail side. My question is, is this a safety clip or a release tool to get the fuel line free from the regulator?(It almost looks like a Ford disconnect tool) Does anyone have a picture of this connection for an 03/04? Does the clip fit up inside the black female fitting? Thank you in advance for any info, feedback, or pictures/diagrams.
Old Apr 25, 2010 | 12:14 PM
GerBeGurGya's Avatar
https://volvoforums.com/forum/volvo-s40-11/s40-wont-start-41033/
Just like you see it on the picture in this thread.Make sure it clicks in on both side.
Old Apr 26, 2010 | 03:48 AM
Originally Posted by GerBeGurGya
https://volvoforums.com/forum/showthread.php?t=41033
This fuel hook-up is different than mine, possibly an older set up. My blue clip is just a ring with 2 tabs pointing up. Mine clips in from the bottom, not the top.
Old Apr 26, 2010 | 06:44 AM
This is how it is on the PH1-PH2 up to 2004.05.On the picture the 03-04 model with the aluminum up pipe from the turbo.After the new body style it could be different.To get ahead here would be important which year your car was really made.Perhaps a picture of the fittings.If you say yours is not like this then you must have the new body style which was made after 2004.05.
Old Apr 27, 2010 | 04:38 AM
I'll have to check exact build date, but it definitly is a 2003 that I bought new in May, 2004 with 26 miles on it. Looking again at the picture, my fuel line is a hard plastic, not rubber and the connector(female end) is on the fuel line, not the FPR. I'll try to get my wife to take and load a picture as that is beyond my ability. In the mean time I safety wired it on with some SS wire and it can't pop up.
UlsterBoy13
Oct 8, 2014 09:57 AM
Galaxy850Sunny
Jun 23, 2014 04:56 PM
CanadianDiesel
May 21, 2014 07:25 PM
Olga240
Apr 9, 2013 02:22 PM
TungstenT2
Sep 30, 2009 08:55 AM
