Fuel Lines
Old Sep 7, 2009 | 06:05 PM
darkdelta's Avatar
Default Fuel Lines
1990 DL240 Wagon
Today I replaced the Crankshat Position Sensor, while doing that I noticed the rubber lines to the fuel rail has cracks in it, this makes me nervous. I looked around at the online part houses, and could not find these. Do I need to fabricate the lines usind SAE 30R9 hose? Or, is there a source for these other than the dealer (if they still stock them)?
Any help would be appreciated.
Old Sep 8, 2009 | 10:10 AM
bubba240's Avatar
The hard high pressure line from the pump/filter to the rail is a dealer only item because of the unique fittings on both ends.
The low pressure return line could probably be fabricated .. its the one that leaves the fuel pressure regulator.
Old Sep 8, 2009 | 11:52 PM
darkdelta's Avatar
Default Thanks
Thanks, I was afraid that it was a dealer only item.
82dizzler
Dec 30, 2010 09:55 PM
m1miata
Oct 15, 2010 06:44 PM
bigdaddyrdpjr
Sep 21, 2010 06:52 AM
cg23cpo
Apr 4, 2010 06:15 PM
axelm
Nov 6, 2008 04:31 PM
