General Non-Specific Volvo Question
Old Dec 28, 2011 | 07:47 PM
A/Ox4's Avatar
Default PS and Coolant Leaks on 1995 940
HELLO.... I'm a member on another forum for MY vehicle, so I wont be a "post and go" kinda person. I'll stick around. I know how it is.
My friend has a Volvo. What model? I dont remember. To be honest, I cant even remember if its a coup or sedan or what. ANNNYWAY... Its leaking. Probably coolant. Just wondering if there are any popular reason that this happens to steer me in the right direction when/if I fix his car.
I am not at all familiar with these and I am just looking for a point in the right direction. I haven't seen the car since he mentioned the leak yet, but I want to know going in if there is a common fail point.
Here is the front of his car (I dont know if it helps at all...)
And here is what he told me:
"Hose for my powersteering pump that goes from the rack to the pump is leaking"
"I think I got a coolant leak too. Coolant is always low when I fill up saw little bubbles coming out from behind a nut thats right on the water pump."
Any ideas? Thanks!
Old Dec 28, 2011 | 09:56 PM
Sound pretty clear to me. Hose from pump to rack leaks (psf) and there is a water pump leak.
It looks like he as a '90 740 GL. Likely a 16 valve motor in it. In '87 all of the black grills were turbo. I'm not sure if the water pump is behind the timing belt on those cars or not. He can give you the VIN and you can run a vin check on Volvo's site or AutoCheck to tell you which motor it has then look for repair instructions from there.
BTW, we usually try to help everyone, even if they never come back.
Old Dec 28, 2011 | 10:00 PM
A/Ox4's Avatar
Figured it would be as simple as those parts leaking. Just wanted to make sure, there wasnt a quirk with these. I do all of my own repairs so I can probably manage.
He might know what motor is in it. I'll ask him when he gets out of work.
Old Dec 29, 2011 | 12:41 AM
A/Ox4's Avatar
THE RESULTS ARE IN!
He says its a 1995 940 non turbo 4 cylinder.
Old Dec 31, 2011 | 12:47 AM
lev's Avatar
lev
Hmm, strange looking '95 940 non turbo front end... I'd have guessed 1990 740 turbo. Somebody has been modifying...
Old Dec 31, 2011 | 12:52 AM
A/Ox4's Avatar
I doubt it was him. But he says hes just gonna take it to a shop... :/
Old Jan 1, 2012 | 08:22 AM
swiftjustice44's Avatar
There are three things exclusive to the 90 740: the width of the grill, the lines on the hood and the size of the "L" filler strips between headlight and grill/bumper. It's a one off thing. In 91, they made the grill smaller to accomodate wider headlight assemblies with built in fog lamps. For the lowly 740 w/o fogs, the filler strip needed to be wider. As the hood lines are inline with the edges of the grill...and the grill became narrower....the hood lines changed as well. So...it is much more common to see a 90 model with the later setup simply because of availability. There just aren't many 90 only hoods out there pristine enough to swap. And...the egg crate grill is indicative of a turbo...although those get swapped around often. Compare the front end above w/ a known 90 740...
Old Jan 1, 2012 | 03:39 PM
They look the same to me.
Obelix
Sep 10, 2009 06:55 PM
Aaronius
May 30, 2008 06:10 PM
Turkey_Sandwich
Oct 28, 2007 08:07 PM
alchu
Aug 23, 2005 02:42 PM
