Grrrrr ! tail light !
Passenger side tail light (940 wagon)tail light works , no brake light ! Driver side is good I have replaced the bulb , no joy. Need the hands of a 10 year old girl to get at this ! Can any of you guys give me a clue? How about a wiring diagram , one wire (brown/white) not attached. This is working on my last nerve ! HELP !!
Take off the whole assembly: three 10mm nuts, use a longish extension--the back should be marked as far as the wire colors and their place.
Even correctly placed those things act up a lot, one can go crazy trying to figure out why a socket won't work right. One of my wagons, '92 740, drives me nuts so I'll replace the whole light to eliminate a constant brake light failure.
I've been having issues also with my 940 wagon and ended up pulling each socket out and bending the contacts out a little more so I know for sure they will make contact and that's solved the problem on 3 of the 4 light problems back there. And yeah a 10mm ratchet wrench with the pivoting head worked great in there, although skinny fingers are still a must. If you have a test light, get someone to help push the pedal or jam a stick between the seat and pedal and check to make sure the contacts on the lamp assembly are even getting power.
88740gle
11-13-2015 08:13 AM
s10lowrider1994
11-16-2014 09:27 PM
buellfire
06-20-2009 12:37 AM
