Have fuel and spark, still misfire
Old Oct 14, 2012 | 01:34 PM
nweuros's Avatar
Default Have fuel and spark, still misfire
Hey guys, just picked up a 85' 244 wagon, clutch was shot, I just finished replacing it. Got it started, runs great... on 3 cylinders.. #2 cylinder is not firing. Pull the plug wire, nothing. So much gas in the exhaust it burns your eyes. Tried new plus, new wires, no cap and rotor, tried switching injectors from a different cylinder, nothing helps.. Any ideas?
http://s33.beta.photobucket.com/user...87444.mp4.html
Old Oct 14, 2012 | 02:20 PM
Compression?
Is it getting spark? Will a bad coil cause all cylinders to miss fire or can it cause 1 to miss?
Old Oct 14, 2012 | 04:25 PM
nweuros's Avatar
Originally Posted by rspi
Compression?
From experience working on Volkswagen, bad coil would be all cylinders, Its getting spark at the plug, and is getting fuel, was going to do a compression test tonight when I get home. The engine does have 300k miles on it, but I have receipts dating back to 92', the old lady took it only to Volvo specialist shops. If compression test comes up ok. Im pulling the head off the engine.
Old Oct 14, 2012 | 08:25 PM
My guess is that the compression is bad. Old people start missing everything. Oil changes, meals, toilet, etc.
Old Oct 14, 2012 | 10:54 PM
note that all 4 injectors run off the same control signal too, so the only unique thing in the injection is the actual injector itself.
but... I've had to throw out several 'brand new' aftermarket spark plug wire sets. the crud sold at places like NAPA etc, 'SUPER PREMIUM SILICONE YADA YADA", pure unmitigated junk. the sockets don't fit right on the plugs, the wire develops invisible cracks, etc. I'll only use Bougicords for Volvos, and Bremi for Mercedes Benz., nothing else.
Old Oct 15, 2012 | 12:48 AM
nweuros's Avatar
I have tried a known working set, no go
Old Oct 15, 2012 | 04:05 AM
nweuros's Avatar
im going to guess its a burnt exhaust valve, which would explain the gas in the exhaust
Old Oct 15, 2012 | 06:34 AM
act1292's Avatar
I would perform a compression check next. A bad coil would be bad for all cylinders. All signals point to one cylinder with internal problems. If one cylinder measures low or no compression, the head must come off for a check of the valves.
g33k
Dec 2, 2012 09:07 AM
volvoQ's
Apr 23, 2011 10:00 PM
joker834
Nov 15, 2006 10:15 PM
