headlight problems
Old Apr 4, 2006 | 09:29 PM
WagHag's Avatar
Default headlight problems
When I switch my park lights on, everything operates normaly. Dash lights and park lights come on. When I switch to the headlights, nothing....no headlights, all interior lights go out. If the radio is on while I'm switching the headlights on and off, there's a short amount of static...I'm not sure if that's relevant. But when i flip my highbeams, they come on till I let go. Fuses are okay but I can't tell the condition of the relay upon visual inspection. Please advise.
Old Apr 4, 2006 | 09:52 PM
colgate41's Avatar
Default RE: headlight problems
Im not sure what is wrong but im sure someone else knows. I have a question for you if you dont mind. Where did you buy those rims from, i think they look awesome on your car, i own a 91 740 4 door turbo.
Old Apr 4, 2006 | 10:32 PM
WagHag's Avatar
Thanks for the compliment! They're 17" Enkei's, model RSF-2. Got 'em on eBay!
Old Apr 4, 2006 | 11:01 PM
WagHag's Avatar
Nevermind! Headlight problem fixed.
Old Apr 4, 2006 | 11:19 PM
colgate41's Avatar
Ok thanks. Good!
Old Apr 5, 2006 | 12:49 PM
igtc's Avatar
I see you fixed your headlights, but I was to suggest your "K" relay was the problem.
To verify, you would be able to get high beams, but no low beams. To test swapping "J" for "K" with or without keys in would give you lo beams.
Take the J back out, and go find a K in junkyard $$$cheap.
Please put your J back in.
Hopefully, this can not only help you, but someone else also.
1990 740 GL 217K
1997 960 124K
Old Apr 5, 2006 | 06:30 PM
WagHag's Avatar
Thanks for the advice! All I really did was pull the K relay, clean the contacts, then replaced. Since a dirty relay caused so much worry, I went ahead and gave them all a thorough cleaning. You're right, others could still benefit from your tip.
Peter1234
Nov 23, 2010 01:19 PM
_HighVoltage_
Apr 2, 2009 11:39 AM
Ahmed
Sep 24, 2008 07:14 PM
thanatos2489`
Aug 30, 2008 02:55 PM
brohism
Jan 24, 2007 09:08 PM
