headlight relay ? 84 245
Old Apr 12, 2015 | 11:16 AM
jaydee's Avatar
Default headlight relay ? 84 245
I just started driving my 84 wagon and found that I had no headlights. The high low beam relay was bad so I pulled one from my parts car .Now the high and low flash when you try to turn on highs but don't stay on,and still no headlights. I've all the relays I could find but all were connected to engine .
Old Apr 12, 2015 | 06:26 PM
probably your headlight switch.
lets see... on a 1984 240, the power goes from the positive terminal (black square thing on left fender well under hood) to the headlgight switch pin 30 via a red wire. yellow wire from switch pin 55(? its fuzzy. might be 56) to step relay pin 55(?) provides the power to the headlights. when you temp pull the dimmer switch, it bypasses the headlight switch.
Old Apr 12, 2015 | 09:44 PM
jaydee's Avatar
Thank you,I will try to pull the switch tomorrow and check it.
sleech
Jan 25, 2020 05:07 PM
Sambar Stag
Sep 4, 2012 01:10 AM
volvoplay
Jul 16, 2012 07:03 PM
treybohon
May 19, 2010 02:41 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
