Help Identifying 1986 Volvo
Hey guys, I appreciate any help in advance.
The trunk has, "240 DL" badges, the title says "240" on it, but the riveted plate on the passenger wheel well in the engine compartment reads, "244 GL."
I would have went with 240 DL but there is no such thing as far as I can tell. Any parts system I check, there is a 240, and a 244 GL, but no plain-jane 240 DL.
So, I don't even know the displacement of this engine, and didn't really need it until now. I'm guessing it's either the 2.0 or 2.3L. I've done a lot of miscellaneous stuff to it like tie rods, wheel bearings, ignition coil and a clutch as of late (PITA).
Anyways, I'm needing to ID this thing because it's time for some real troubleshooting. Car won't start, then a week or two later drives great for a day or two, then won't start again.
I'm thinking fuel related but I can smell fuel so I dunno, my experience says either a fuel pump or relay works or it doesn't. Anyone had experience with a relay or pump being intermittent?
I've asked a ton of questions, but I really need to ID this car and start troubleshooting it's starting problems. Again, I appreciate any help in advance.
Thought I'd toss in a pic...
What does your VIN # tell you?
http://www.brickboard.com/FAQ/700-90...onNumberCoding
Of course someone may have changed the engine/some of the other components but as a start the VIN can tell you a lot about what's under the hood.
Happy wrenching!
Koos
Happy wrenching!
Koos
Well a 240 and a 244 are the same thing. 244 is the 4 door version of the 240. But looking at it s a 240GL, or 244 GL, again since its a 4 door.
It should have a 2.3liter motor in it. And it looks like someone put a different front quarter panel on the car, since the bumper trim is missing and the red is a different color. DL Gl is basically the same exact car except in different trim, and possibly markets.
I would start with having a good look at two items: (1) the fuel pump relay, and (2) the 25-amp fuel injection fuse. The relay is a 1"x2" white plastic box mounted on the inside firewall just above the passenger's right foot. The fuse is mounted next to the headlight hi-lo relay on the left fender right behind the battery.
Hey well alright, I appreciate the help.
As far as the front fender, it's the only fender that I waxed when I took that pic. I was showing someone how good the paint still was. I'm not sure what you mean by bumper trim missing... ?
I will check the relay and I will also check the VIN using the link above. At least now I can find manual.
I'm still curious as to why a 240 DL doesn't show up on any parts systems? None of my local part stores show a 240 DL and neither does Rock Auto where I usually do my first bit of research on parts.
On a side note - anyone put a 302 in one of these cars? I've heard of it being done and I've got a 302 H.O. sitting in my garage begging to be freshened up and slapped in there as probably a forever project. For now I'd like to get the sucker rolling again. Ice cold air, burn-ya-up heat and decent mileage.
Okay well I've got some work to do, thanks again for all the help.
240DLighted
11-28-2014 05:00 PM
Black Belt Turbo
13
12-06-2006 01:46 AM
SirJeffrey
07-05-2006 09:06 PM
