help on timing 740
Old Aug 1, 2010 | 01:39 PM
91sedan's Avatar
Default help on timing 740
i have a 91 740 volvo with b230f which way advance timing by turning the distributor know one way retard another way advance
Old Aug 2, 2010 | 01:00 AM
tedv's Avatar
740 does not adjustable timing in the US models-dist. does not move.
Old Aug 2, 2010 | 08:29 AM
91sedan's Avatar
my volvo was made belgium not the us
Old Aug 2, 2010 | 09:54 PM
tedv's Avatar
Oh, well, in that case... still not adjustable!
Old Aug 2, 2010 | 11:11 PM
swiftjustice44's Avatar
Do you have Motronic injection? Or Bosch LH2.4? Assuming you have your timing belt installed correctly, the only way to adjust the LH2.4 timing is by grounding various pins on the ecu. Generally, if an LH2.4 motor is out of time, it is the result of someone neglecting to get the intermediate shaft lined up.
Edit...just checked and Motronic was only used on the B230ET. Your non-turbo is LH2.4. Has the timing belt been changed lately?
Old Aug 20, 2010 | 12:34 PM
91sedan's Avatar
it non turbo b230f and yes timing belt has been changed i set timing at 0 on lower timing cover but how to set it at stock timing cause some people says its 12 degrees btdc
bobm
May 14, 2015 01:16 PM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
