Help...warning buzzer will not go off!
Old Oct 13, 2008 | 08:10 AM
mr240's Avatar
Default Help...warning buzzer will not go off!
Just replaced OD relay, now overdrive works great! But new problem occurred. When you turn the key on, the warning buzzer will not turn itself off like it normally does. It remains on...very annoying. Any ideas on where to begin with this dilemma?
Old Oct 13, 2008 | 08:13 AM
Default RE: Help...warning buzzer will not go off!
So it is on while you are driving?
Old Oct 13, 2008 | 08:17 AM
mr240's Avatar
yes, stays on..... from time u turn key on till u shut it off. Just started after fixing the od relay.
Old Oct 13, 2008 | 09:24 AM
Thats really weird. Check all the fuses and the fuse panel. You might want to remove all the fuses and wire brush the fuse box then install the fuses.
At first I was thinking maybe the door pin was bad but then if it stops when the key is turned off that scratches that.
dmg4
Dec 22, 2021 11:03 PM
karladaune
Jul 6, 2011 01:36 PM
mcaanda
Apr 27, 2010 01:00 PM
StrangeBrew
May 29, 2008 07:56 PM
pam@picton.net
Aug 4, 2005 01:46 PM
