High Beam works but no more Lo Bean
Old Jun 7, 2019 | 10:50 AM
tat1642's Avatar
Default High Beam works but no more Lo Bean
Hi, I have 1993 240 station wagon.
I was using High Beam while driving country side road, now never back to Lo beam again....
Headlight switch On/Off works. Passing flasher High Beam works while headlight is Off.
When I pull lever, there is "click" sound but stay High beam ON all the time now.
Big silver metal covered relay at passenger side fender make sound when pull lever.
Anyone can help this?
Thank you so much. TAT
Old Jun 13, 2019 | 06:02 PM
sounds like the headlight 'step' relay has failed and gotten stuck in high mode.
Old Aug 2, 2019 | 06:49 PM
tat1642's Avatar
Thank you Pierce. I replaced that step relay and now back to normal.
I also opened old relay cover, cleaned contact by sand paper. Thought it could have done this way instead of purchased brand now, it was expensive
Old Aug 3, 2019 | 04:08 PM
sandpaper might make them work briefly but it also removes the protective plating and the contacts are likely to oxidize fairly quickly, so its often a short lived solution.
I use a thin strip piece of paper with a drop of Deoxit D100 to clean relay contacts.
redblockturbobrick
Dec 19, 2018 11:31 AM
xDread92x
Nov 26, 2016 04:13 PM
D.Moore
Dec 30, 2011 10:05 AM
Dpoupore
Nov 22, 2011 09:53 AM
dljdad
Jan 4, 2010 05:39 PM
