High Idle issue
Old Mar 9, 2010 | 11:33 AM
im4rcn's Avatar
Default High Idle issue
1991 940 GLE, When I start the idle sets at 1050 rpm, but after 15-20 seconds it"ll climb to about 1800rpm and won't drop. I've checked for vacuum leaks and found none, unplugged and checked all wiring connectors, found no corrosion on any plugs, good fuel pressure, plugs are burning clean - none are fouling or white or oily dark, tps is reading .5 volts, is this the correct reading? Help please
Old Mar 9, 2010 | 11:56 AM
cbevis's Avatar
Idle Air Control valve.
Old Mar 9, 2010 | 04:04 PM
im4rcn's Avatar
Hey thanks Cbevis, Pulled the iacv and washed down with throttle body cleaner, allowed to dry and reinstalled. Started car and same issue continues. Repulled valve and had my son turn the ignition on and saw the valve move but not rotate more than a 1/8 inch. Is the valve supposed to continue rotating or just move a small amount? After I reinstalled I fired the motor and allowed it to idle for 25 minutes but the idle remains at 1800 rpm. Any more suggestions out their?
3s0x
Mar 22, 2012 08:06 AM
3s0x
Mar 20, 2012 07:07 PM
rosesforlily
Nov 5, 2009 09:23 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
Muskoka
Oct 23, 2005 11:42 PM
