How to get more power?
Old Feb 21, 2005 | 04:57 PM
jc740T's Avatar
Default How to get more power?
What are the best ways to get more power out of the 740T engine? Also, where do the most common power losses come from? My car has 175K, and I am going through it and replacing hoses, ect....
I have modded several GM cars, but this is my first swede.
Thanks.
Old Feb 21, 2005 | 06:33 PM
Default RE: How to get more power?
The easiest way to get a few horses of the bat is go with a cone filter.Adjust the waste gate on the turbo and install a regulator to adjust boost pressure.
Old Feb 21, 2005 | 08:36 PM
jc740T's Avatar
Ok. Where would I go to figure out how to do that? Thanks.
Old Feb 21, 2005 | 09:16 PM
You will have to remove the rod at the wastegate on the manifold side and loosen the nut and back out on it one turn to start.That will open the waste gate more.I have a picture in this post so it will help you.Then the vaccum line that goes to the waste gate valve you can stick a regulator inline to manualy adjust the boost.If you want you can just adjust the rod till you get a regulator.
[IMG]local://upfiles/853/5EAEB5F927CB4008BFBD05724FA97AA2.jpg[/IMG]
Old Mar 8, 2005 | 06:55 PM
jc740T's Avatar
Where would I find a cone air filter for the 740t? Is it an easy job? thanks. jnc
Old Mar 8, 2005 | 07:39 PM
You should be able to find a cone filter at any autoparts store.No it is not hard to install.
240DLtuner
Jun 25, 2023 08:46 AM
shsaliaga
Dec 12, 2011 11:41 AM
gordon368
Jun 6, 2009 03:01 AM
Painkiller
Nov 3, 2008 01:40 PM
HelgaTheS80
Jan 9, 2007 01:54 AM
