How to replace 1990 240 alternator!?
Old Jan 3, 2015 | 03:11 PM
MccDylon's Avatar
Default How to replace 1990 240 alternator!?
Hey I'm looking on forums here and I can't seem to find any videos or diagrams of how to take off my alternator on the 90s I see 93s but there different... I'm concerned about the wiring.. Any help.. .? Thanks new to this forum
Old Jan 6, 2015 | 07:07 PM
Try posting in the correct area for a 240, way more likely to get an answer rather than
"New Member".
Also try youtube.
Old Jan 6, 2015 | 09:36 PM
busdude2's Avatar
Remove the plastic skid plate under the engine. This allows bottom access to the alternator. Disconnect the battery (negative) ground wire. Note ( draw a picture ) where the wires connect to the alternator. Remove wires from alternator. Loosen top adjuster, and back off to loosen the fan belts. Loosen the bottom ( long) pivot bolt. Remove the v belts from alternator pulley. Remove the short bolt that goes through the top of the alternator. Remove the bottom ( long ) pivot bolt. remove alternator from the vehicle.
Old Jan 6, 2015 | 10:27 PM
pretty much all volvo 240, 740, 940 bosch alternators have the same 3 wires. big massive red wire from the B+ terminal on the alternator that goes to the power terminal on the starter (and on to the + of the battery). skinny red wire that goes to the D+ terminal, this provides the 'kickstart' current via the BATT (ALT) light on the dashboard, and a ground wire.
shavalena
Jan 7, 2017 02:43 PM
craigshensel
Jun 13, 2012 03:11 PM
craigshensel
Apr 12, 2012 07:53 AM
dldunckel
Jan 20, 2010 07:02 PM
cheesenacho
Sep 18, 2009 10:04 AM
