How To: Replace Interior Door Lock Release Casing
Old Dec 5, 2022 | 01:10 PM
teerey's Avatar
Default How To: Replace Interior Door Lock Release Casing
Putting my process here since it was a little more difficult than expected for what I thought would be a very simple job and there weren't really any sources available online to reference and confirm what I was doing. (I have an 1991 240 Sedan)
This is the process I used to replace the interior door lock release lever (interior door handle) casing. My driver side casing was shattered when I got the car and the passenger side was cracking so I needed to replace them--90s plastic doesn't age well. I purchased an aftermarket replacement from SwedishCarParts, they have both driver side and passenger side available; Voluparts also has OE ones available (as does VolvoPartsWebStore) but I guess Volvo only stocks black ones nowadays.
Here is the process:
  1. Use a plastic pry bar (or screwdriver) to remove the casing frame
  2. Remove the door card and moisture barrier(lots of guides on this forum for that)
  3. Remove the casing
    • If it's damaged it'll probably shatter enough to get it out, otherwise it's a clip-in
    • The front portion is a long tab that slides in a hole in the door and the rear portion is a clip that you must bend inward to install or remove.
  4. Remove the lock release lever ****
    • I you don't care about damaging it, use brute force
    • Mine was very stuck and I didn't want to damage it with pliers so I sprayed silicone lube up inside, then wrapped it in a wet washcloth that was microwaved for 2 minutes and it was able to come off very easily by hand
  5. Slide the replacement casing over the metal tab that the **** came off of
    • There's a slot in the bottom of the casing where that metal lever slides in
    • Driver and passenger side casings are not interchangeable, the slot on the casing has a circular pin at one end, that pin should be oriented towards the front of the car
  6. Before fully installing the casing, reinstall the metal lever's plastic ****
  7. Install casing and reinstall all removed door components--Done!
aaknj
2001-2013 model year XC70
Mar 3, 2018 05:35 PM
biz421
Dec 11, 2016 12:29 PM
Nathan_1998_S70
Oct 12, 2011 03:26 PM
frank48photo
Apr 2, 2011 02:05 PM
peetnik
Oct 22, 2010 12:10 PM
