Passenger door lock stuck. Need Help.
Old Oct 11, 2011 | 03:36 AM
Nathan_1998_S70's Avatar
Exclamation Passenger door lock stuck. Need Help.
i have a 1998 S70 and my passenger side door lock is stuck and i can't get it to unlock. The door won't open from either side. I'd like to not damage my interior door panel to access the latch. What can i do?
Old Oct 11, 2011 | 08:44 AM
Have you tried to remove the door panel? You will probably have to take the seat out first. Before you do that, disconnect the battery for 30 minutes to avoid setting off the SRS light and by all means, be carefull not to set off the seat airbag.
Old Oct 12, 2011 | 03:26 PM
i was able to pull the top of the door panel out far enough to get a screwdriver into the lock mechanism and got it unlocked. turned out the cable from the interior door handle had come out of its groove and unhooked some plastic arms on the lock. successfully fixed with minimal tool-mark damages.
volvomommy
Apr 4, 2012 09:08 PM
southy
Dec 27, 2010 05:40 AM
SKRIBZZRC
Nov 17, 2009 02:58 PM
Barnaclebill
Jan 22, 2009 08:03 AM
jonnybobs
May 30, 2008 07:59 AM
