How to tighten B21 alternator belt
Old Apr 30, 2016 | 05:23 PM
xDread92x's Avatar
Default How to tighten B21 alternator belt
Hi,
I am dealing with a 1980 Volvo 245 and the alternator belt keeps coming loose and squealing horribly. It is a 2.1 with just an alternator and power steering belt. I don't see the 10mm B230 adjusting screw on this older model so I have been using a large flathead screwdriver to pry the alternator back to the belts tightest position and then quickly tightening the 13mm. I overtightened today and the whole bolt broke in half so now I have to get a new bolt and nut. I noticed there was no washer but is there suppose to be one? Also, I believe there could be a possibility the locking nut was crap and the engine vibration was loosening the nut thus the belt loosening and the squeal etc. Thoughts?
Thanks
Old Apr 30, 2016 | 06:25 PM
you should also replace the rubber bushings that the alternator cradle pivots on, they wear out, cause the alternator to sit at a slight angle, which causes all sorts of belt issues.
meusman
Aug 30, 2010 07:10 PM
trebuchet5684
Apr 30, 2010 09:45 PM
parmbrust
Oct 18, 2009 07:29 AM
cw9000
Jun 18, 2009 08:15 PM
Mad-Ass
Jul 25, 2004 05:22 AM
