I used DOT3 instead of DOT4. Problem?
Old Sep 21, 2005 | 12:15 PM
Marks 240's Avatar
Default I used DOT3 instead of DOT4. Problem?
Hi,
After buying my 240 I checked over the brake system and changed the brake fluid. I've done this several times with other cars. The car is a 1992. Thinking DOT3 fluid has been the standard for years and DOT4 is a relatively new invention, I put Prestone Synthetic DOT3 fluid in my Volvo. I just bought a Bentley manual and it warns against using DOT3 fluid and to only use DOT4 or risk brake system failure. Have I made a big boo boo? Should I change the fluid out and replace it with DOT4? Has anybody had any problems with this?
Thank you,
Mark
Old Sep 21, 2005 | 10:00 PM
Default RE: I used DOT3 instead of DOT4. Problem?
I would flush the system really good with the Dot 4.
Old Sep 21, 2005 | 10:49 PM
Buck's Avatar
Organic and synthetic fluid are not compatible!!
Old Sep 21, 2005 | 11:53 PM
Carbuff's Avatar
ORIGINAL: Buck
Buck, not 100% true...
Organic (glyptol-based) and SILICONE fluid should never be mixed.
It's confusing because you have DOT 3, DOT 4, DOT 5 (silicone), and DOT 5.1. <SIGH> The debate has flared up on many Lists over the years. Synthetics are becoming more prevalent nowadays but they are still Gylptol.
Old Sep 22, 2005 | 10:02 PM
Buck's Avatar
I bled my brakes and put synthetic in to top it off. It sat there never mixing with the organic. I have to draw it off and put in organic and it worked fine.
Old Sep 23, 2005 | 11:30 AM
Marks 240's Avatar
Thanks for the replys. I bought a gallon of DOT4 fluid yesterday. Last night I re-bled the brakes and ran about 3/4 of a quart of DOT4 fluid from the reservoir thru each caliper. Now I have the cleanest brake lines and cylinders on the east coast. I'll keep an eye on it to see what happens. Every car I've ever had uses DOT3. From now on I'll check a book first rather than assume. You know how one can spell assume.
Mark
ycartf
May 6, 2013 11:19 AM
sampdoria
Jan 24, 2011 03:27 PM
J Dubb
Feb 24, 2010 04:51 PM
yoyomai
Dec 14, 2009 07:08 PM
axelm
Aug 29, 2008 05:30 AM
